Old 02-14-2024, 09:45 PM   #1
Cotten
Liked 563 Times in 70 Posts
Default Re: National Records
My thoughts on national records.
1. Records are set at points races.
2. During qualifying you place an "r " on the window as we've done in the past
3 If you achieve the record and pass tear down all your runs for that event do not count towards the ahfs. If you fail to set the record all the runs count towards ahfs.
3. Each racer can earn 10 pts once a season for setting a record.
Cotten is online now   Reply With Quote
Old 02-14-2024, 10:08 PM   #2
Stephen & Horace Johnson
Liked 161 Times in 52 Posts
or gain a grade point
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 02-14-2024, 11:01 PM   #3
Paul Wong
Liked 419 Times in 85 Posts
I really think many tech officials look at setting a record at a points race as a burden. I used to set records every year, but it’s something that has lost its value to everyone including NHRA. I do not regret the time of setting records, as they were great times. Tear down was a major right of passage for me for records or getting picked by tech officials
Paul Wong is offline   Reply With Quote
Old 02-15-2024, 12:22 AM   #4
DG
DG's Avatar
Liked 449 Times in 98 Posts
The only place to set a record without hurting your combination is at National Opens. I don't know about other divisions, but in Division 7 the National opens are in the summer when tracks are slow and we usually don't run until after junior dagsters around 11 am. Good luck setting a record in those conditions.
DG is offline   Reply With Quote
Old 02-15-2024, 12:42 AM   #5
Gary Evans
Liked 16 Times in 11 Posts
This year there is no schedule for national opens in Div 7
Gary Evans is offline   Reply With Quote
Old 02-15-2024, 09:14 AM   #6
rsalemi
Liked 23 Times in 10 Posts
When I last set the record (2011?) I didn't get a picture or even a line in the results in Nat Dragster. NHRA hasn't cared much since then!
rsalemi is offline   Reply With Quote
Old 02-15-2024, 10:26 AM   #7
DG
DG's Avatar
I just checked the Division 7 schedule and they have posted a National Open at Top Gun Raceway, Fallen Nevada on June 1-2.
Old 02-15-2024, 11:06 AM   #8
Gary Evans
Well that’s a start, but not a place to set a record. 12 sec cars have a difficult time getting down that track. Hopefully a natl open at Redding???would provide a better opportunity to set a record
