Old 02-09-2024, 01:55 AM   #1
1700camaro
Liked 228 Times in 117 Posts
Default Hoosier C30 Compound
Anybody using the highlighted radial below. I've used the C06 lightweights with good results; was told these tires wouldn't work. I had no issues with them working & got an easy 150 runs out of them.
The tires shipped today & supposed to receive them tomorrow. Hopefully test/race them next weekend.
1700camaro is online now   Reply With Quote
Old 02-09-2024, 11:31 AM   #2
Barry Polley
Guest
Posts: n/a
Default Re: Hoosier C30 Compound
That tire was designed for FS cars. Would work well on yours.
Old 02-09-2024, 12:26 PM   #3
1700camaro
Thanks Barry!
We are going to find out soon enough.
Old 02-09-2024, 05:48 PM   #4
1700camaro
Got the tires, they have 94" Factory Stock molded in the rubber under the tire size. Must be a rules thing.
Old 02-12-2024, 11:26 AM   #5
novassdude
Liked 136 Times in 49 Posts
Looks like it is their way of getting a 10 inch tire in stock. We will see if NHRA lets anyone run them or only FS cars.
novassdude is offline   Reply With Quote
Old 02-12-2024, 11:51 AM   #6
1700camaro
I'm a bracket racer so, I don't know what the rules are. I would assume with Hoosier molding the 94" Factory Stock under the tire size that they're only for FS.
We'll see if they work for a bracket car.
Old 02-12-2024, 12:32 PM   #7
J.R. Haddad
Liked 1,471 Times in 308 Posts
NOVASSDUDE. That genie is already out of the bottle. I have seen quite
a few Stockers run them in the last 2 seasons. I'm not saying a new rule couldn't be put in place to not accept them, but they have been run quite
extensively for 2 seasons. Keep in mind, Factory Stock Showdown has
9" inch tire rule as well.
J.R.
J.R. Haddad is offline   Reply With Quote
Old 02-12-2024, 07:56 PM   #8
1700camaro
Tires are mounted & balanced. At 20 psi the tires measure dead-on 94". I mounted these on a 10' wide rim. We'll see how they work this coming weekend.
Our primary tire is a 29.5x10.5 M/T PBR.
Old 02-18-2024, 12:32 AM   #9
1700camaro
I like the tire so far; they helped me get down to six cars today & a little bit of money.
We have 9 runs on the tires. The first 4 runs woke up the wheelie monster again with having to peddle the car on a few of the runs. The plan for now is to have these tires as a spare set & continue running our primary tires.
Old 02-18-2024, 06:02 AM   #10
J.R. Haddad
1700, how were your 60 ft times compared to your other tires? And ET compared to other tires?
Thanks,
J.R.
