Old 01-24-2024, 03:22 PM   #10
Doug Hoven
Liked 853 Times in 164 Posts
Default Re: Ways to check on the use of illegal devices
Unfortunately the only way to enforce it is for either NHRA to have tech inspectors begin randomly pulling racer's cars apart. Something like that will probably never happen, so until a racer lets his guard down and makes it obvious of something "fishy" going on, I'm thinking there won't be any action to enforce electronic rules. I think "traction control" is given more credit than it deserves. Unless it's a heads up situation, 9 times out of 10, if a car begins to break tires loose to the point where "traction control" would kick in, there is no way that they are going to run close to their dial-in. Starting line timing retards, while a form of "traction control" would be a losing battle to try and outlaw them. You'd have to deem every aftermarket ECU illegal, as well as all "programmable" MSD ignition boxes capable of using a trigger to cut timing and ramp it back in over some time. This coming season will be my 4th full time season, so my experience is limited, but I remember spectating the late rounds of a race at Numidia, where a driver did not once look ahead or over at the other lane, then proceeded to "spot drop" and run within a few thou of their dial. Kind of suspicious IMHO, but with enough practice, and the right car, I suppose you could spot drop and be almost dead on every run.
1189 F/SA
Defunzalo Racing Enterprises
