Bill, Adjusting it the way you said I can't get it to work good in both holes it's either one or the other,( going from low to park ) so I tried to split the difference and that didn't work to good either. The bracket that mounts on the trans did move some that was when I took off the bracket and wielded two together put it back on readjusted it again. Seems to work for a period of time then WA LA I'm back in the dummy mode.Thanks for your help Bob.................
P.S. The bracket is mounted on trans. Last edited by Bob Verwold; 05-14-2008 at 08:38 PM. |
Bob
I think you have some missmatched parts, How did it work in low vs high? Billy
Bill Baer 3391 SC, 339B SC, QR |
Didn't really try in low to drive
Bob
Try high, neutral, and reverse while your under there again the lever shouldn't move when the cable is removed. I suspect that the cable attachemt point on the lever is to far frm center and does not move the lever far enough in both directions. Billy
Bill you have an e mail
