Old 05-14-2008, 01:15 PM   #1
Jeff Lee
Jeff Lee's Avatar
Default Re: To High Of A Wheel Stand Help
I would instal a manual steering gearbox. It sounds like you still have the p/s gearbox in the car.
And that's not a huge wheelie. It's impressive and fun. You'll get used to it! Look over your shoulder and you will learn to tell if the run is straight or not.
Jeff Lee 7494 D/S '70 AMX
Old 05-14-2008, 02:33 PM   #2
BIZMANRACING
BIZMANRACING's Avatar
i do have the orginial p/s gear box in there. tough to turn the wheel but 6ft 250 i can handle it (at least i think so) but what will the manual gear box do? also, what do you mean about looking over your shoulder to see if your going straight?
yes its fun and exciting. just don't want to brake anything.
as for the link for the sterring damper. i read it all. thanks you. i haven't made the phone call yet. but, does it make a difference that my car is a 79 camaro not a thrid generation unit which is what the catalog calls for/
thanks
S/ST 1739
Carlos Mendes
BIZMANRACING is offline   Reply With Quote
Old 05-14-2008, 02:39 PM   #3
Ed Wright
Ed Wright's Avatar
I look to my left and watch the wall or center stripe, depending on which lane I'm in. My bracket engine often stayed up well into 2nd gear, my class engine does about what your doing there. Should cause no problems. As Jeff said, you'll get used to it. I would have a good front end shop check for and correct any bump steer.
Ed Wright 4156 SS/JA
Old 05-15-2008, 11:48 AM   #4
Bryan Worner
Liked 534 Times in 86 Posts
Once you get used to doing that "normal" wheelstand you'll be able to tell if your going straight or not without even looking out the side. I'm used to doing 60' + wheelstands and have experienced unloading, going toward the centerline and even tagging the wall once. It's like anything else, doing it over and over, you'll get a feel for your normal launch.
Bryan Worner is offline   Reply With Quote
