Old 12-21-2023, 09:34 PM   #1
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
Default Re: New HP Numbers Posted
Originally Posted by Jeff Dona SS3269 View Post
If a 54 year old combination is getting hp we don’t have a hp problem we have an index problem across the board . There have been a lot of advancements in stock and ss since the last index adjustments. We cant just simply keep adding weight to combo’s.
Some cars didn't get advancements in stock that the Chevy's did. My car already had a solid cam, adjustable shaft rockers, a thick rigid block, good valves, double springs, a good mani, more than enough carb CFM, a good front and rear suspension and good rods and crank. Most older cars shouldn't have to add weight, moving up a class is a good option as very few older cars would need to be higher than the AA/SA class.
Paul Precht is online now   Reply With Quote
