Liked 10,896 Times in 2,255 Posts
If you think NHRA made an error ask you division Tech director to check on it. The class will change only with the HP on the OEM heads. With approved after market heads just the weight is adjusted up or down. Try doing the math yourself and see if you get the same result.
Check and see if the Camaro, same platform, and year model received the same treatment. Last edited by Larry Hill; 12-13-2023 at 09:30 AM. |
