Old 11-01-2023, 10:17 AM   #1
kjclark887
Liked 37 Times in 8 Posts
Default Re: $10,000 AA/S SHOOTOUT at 2024 US NATIONALS
Originally Posted by Jason Shepard View Post
Also a good question. Pulling and adding that much weight is not easy for some racers.
Pulling/adding weight should be the least of someone’s worries when racing for 10k, no?
kjclark887 is offline   Reply With Quote
Old 11-01-2023, 11:23 AM   #2
Jason Shepard
Jason Shepard's Avatar
Liked 114 Times in 29 Posts
No, I suppose not. There is a difference between weight box weight and permanent/tac welded on weight.
To be clear, I think this will be an awesome event! These special shootout races are a lot of fun, and I hope they get a big turnout for it! I was just thinking out loud...
Jason Shepard is offline   Reply With Quote
Old 11-01-2023, 12:12 PM   #3
Kenny Bomar
Liked 424 Times in 50 Posts
I am running a zl1 Camaro stick car my minimum weight is 3505 would the weight remain the same for the shootout ?
Kenny Bomar is offline   Reply With Quote
Old 11-01-2023, 05:38 PM   #4
Bpozzi
Liked 120 Times in 21 Posts
No if you are running the zl1 you will have to be #3730.
296B AA/SA
296B FGT/G
Bpozzi is offline   Reply With Quote
Old 11-01-2023, 06:38 PM   #5
Kenny Bomar
Well that eliminates any chance of my combo being competitive
Old 11-01-2023, 06:44 PM   #6
SS/GSI
SS/GSI's Avatar
Liked 759 Times in 109 Posts
Mr. Bomar, in order to participate in the shootout your car cannot weight less than 3710(20#'s under your A/S minimum).
In order to create a level playing field, cars participating in the AA/S Shootout will need to adhere to their Shootout minimum weight sticker on every run.
If you are concerned about qualifying for the eliminator, you can run A/S or AA/S at your minimum weight and not participate. The general population of participants would not be able to get to minimum AA/S weight. If competitors could get close to minimum weight it would most likely require the removal of the majority of ballast in their cars. This would not be conducive for setting up the cars to the marginal track conditions we have seen the last few years at Indy.
Again, this shootout is for those who want to participate and given the feedback from the racers at Indy over the past couple years, this platform has been well received. Tnx
Kevin Gaffney
1123 SS/GA
SS/GSI is offline   Reply With Quote
Old 11-01-2023, 10:04 PM   #7
Kenny Bomar
I didn’t understand that is why I asked, it at that weight I couldn’t be competitive I hope there is a good turnout it should be fun !
Old 03-23-2024, 04:46 AM   #8
Cglrcng
Cglrcng's Avatar
Liked 335 Times in 186 Posts
Talking Re: $10,000 AA/S SHOOTOUT at 2024 US NATIONALS
Don't take the ballast out, put a flyweight driver in...For rent or lease cheap 115 LB. (Wet) weight driver. Pros: Will hammer the tree, not afraid of red (too often by mere thousanths), but your front tires have much more rollout to adjust to than a 20" tall FWD slick, you can add more ballast to the box probably...Cons: Have not lifted a front tire off the track surface since the Mid 80's (would almost die to go high and shift in the air), have not left the line in elims' 2nd. since the early 90's, and has not driven a stick car on track since the early 80's, but I learn fast, drive straight, don't eat much, and will sleep anywhere to race.
Gary Lucier - 7832 STK. / 7832 E.T. EF/S Slow Sled. I am, but a simple test of your true patience. So, do all the really "Big Wheelies" you can!
Cglrcng is online now   Reply With Quote
Old 03-23-2024, 10:00 AM   #9
Liked 10,738 Times in 2,234 Posts
At this year’s Indy class was laddered after Q2. How will the mix of FI cars and 10 K shootout cars be paired if NHRA has them laddered? I don’t think NHRA will allow a C1 looser to race in C2. I’m not saying the carburetor car would loose but it might to a minimum weight FI car. I hope y’all get everything worked out it could be a good show.
Old 03-23-2024, 11:59 AM   #10
SS/GSI
SS/GSI's Avatar
Larry, there is only but a few EFI/Paper car combos in the entire guide that could fit into AA/S. Also, to my knowledge, none of the few combinations have yet to be ran in stock eliminator with a stick. No car has ran AA/S at the US Nationals since its addition to the class category guide. Should an individual now, all of the sudden, wish to run AA/S with one of these rare combinations, it would obviously be to MF the shootout; however, should this arise, its ok...they should just make sure they bring lots of tools and gaskets LOL
This event is for us old school guys by us old school guys...we just want to have fun and race each other. Hoping to have a great turnout and event.
Kevin Gaffney
1123 SS/GA
