Liked 373 Times in 129 Posts
When the rear end was installed we went from a 13.9 to 13.4 ET at high altitude, but I still felt the truck didn't pull through low gear like it should, 1.92 60 foot, knowing the stocker trucks went 1.77 @ Denver this bothered me, although I knew they were 300 pounds lighter, but didn't have my HP. My focus turned to the driveline which is a disaster on a 79 C-10, heavy rear brakes, heavy discs up front, which only accept a heavy tire rim combination, 6 lug. So I looked at the Lamb front brake setup and decided I didn't want to spend the money and wait (wish I had) so I tried to go the LM1 Camaro front disc setup which required I believe a 1981 and newer front spindel, but could never figure out the caliper setup so I had the original style heavy front discs redrilled for a car bolt pattern. I now could get a race style front tire and rim on the truck. I still had the ultra heavy 2 piece drive shaft robbing me............................
So we headed for Kearney Nebraska 2130 feet elevation 4300 DA with bad humidity and ran 12.80 @ 105 MPH but still a horrible 1.82 60 foot, still in the back of my mind a not so quick stocker truck runs 1.77 60 in Denver running 13.8s? I've got something going on here...................
1320/105 = 12.57 getting robbed Anything that can be done to hit the tires harder at this point only responds with a drastic reduction in ET-more to come. Last edited by HP HUNTER; 10-06-2023 at 10:00 AM. |
Keep in mind at this point this truck has been running about 6 1/2 years from the time it was built to the 12.80 @ Kearney and has about 20,000 miles on it, mostly with the 5.13 gear, we drove it a lot, and the late Harold Bettes felt pretty comfortable over in the passenger seat going lunch!
Liked 482 Times in 159 Posts
Just how much time was spent porting the heads ? I realize that is something you have a lot of experience in.
#5 | |
Heres some information on the 327 build: Heads from start to finish maybe 40 hours approx Flow @ 28 inches SF 600 4.030 bore, 2.020 Intake valve .200 don't remember .300 193 .400. don't remember .480 239 Peak 259 around .650 lift Hp was 445 HP @ 6600 RPM TQ was 400 for one RPM point, 390s flat for a long time Last edited by HP HUNTER; 10-06-2023 at 10:42 AM. |
So we moved to Texas, I ran the truck @ 450 feet elevation, 2000 DA with the 327 which resulted in a 12.13 @ 107+ with a 1.63 60. at this point I knew the truck would never run 11s in the heat so I decided to build a 350 hoping this would put it into the 11s. Notice my ET @ Kearney 2130 feet 12.80 dropped to 12.13/7.63 @ Little River 450 feet. My drive line losses were showing what every bit of extra power was worth.
1320/107.5 = 12.27 much better at this point, but far from done.......... Last edited by HP HUNTER; 10-10-2023 at 10:07 AM. |
Liked 81 Times in 45 Posts
Are you doing dyno work in Texas? Little River has a lot of history.
