thanks for the info does anyone have the part number for the volarie style master cylinder? would i be better off going back to the stock master cylinder? also i was told to delete the proporting valve all together was that a bad idea?
Liked 10,701 Times in 2,228 Posts
I race the Cuda without the valve.
#3 | |
Liked 252 Times in 94 Posts
This is a dumb question, but do you have the lines hooked up to the proper ports on the master cylinder? Front to the rear and rear to the front. Did the car have a power booster in it originally? Like someone else said in an earlier reply, the pedal ratio could be the issue.
George Mirza D/SA 1236 ‘71 Duster 340 |
Don’t use the stock type rubber hose over time it will deteriorate and will cause a restriction on on the return flow back to the master cylinder.
thanks for all the info parts are ordered
Liked 72 Times in 36 Posts
If installing Disk Brakes in the front and keeping the stock rear brakes you should install a Residual Pressure Valve i'm not too sure about the one you should use a 2 LB or 10 LB between the Master cylinder and the rear brakes according to Strange Engineering it also says to replace the 3 rubber hoses and install 3/16 steel lines
Kenney Kelley |
Liked 2,483 Times in 697 Posts
Didn't the Disc Brake master cylinders have a residual
pressure valve right before the lines factory. It looks like it would install in any mopar cylinder. We do not use any on all our race cars. I worry about even a small amount of drag.
