Old 09-08-2023, 09:26 PM   #1
back for more
Default poor braking
changed from stock front drum brakes to lightweight front disc brakes and used master cylinder required 1-1/8 bore brake pedal is hard as a rock car does not slow down checked the ratio on the brake pedal measures perfect the car is a 72 dart any help is appreciated
back for more is offline   Reply With Quote
Old 09-08-2023, 10:04 PM   #2
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Default Re: poor braking
Have a used once Wilwood Master cylinder for sale.
Dan
Old 09-09-2023, 08:09 AM   #3
Liked 10,691 Times in 2,227 Posts
On our 72 charger when we changed breaks from power to manual the linkage under the dash had to be changed to a different hole to give us more of a mechanical advantage. I want to say the bore in the master cylinder was smaller making it easy to build psi.
Good luck.
Old 09-09-2023, 09:31 AM   #4
Rory McNeil
Liked 1,103 Times in 301 Posts
Like Larry said, at least on Fords, the manual brake cars came with a different brake pedal, with a pivot for the master cylinder pushrod closer to the pivot for the pedal itself, for more mechanical advantage. Again, with my Fords, manual master cylinders a re usually a smaller bore, like 7/8" or 15/16" diameter, compared to over 1" for a power brake application.
NHRA 6390 STK
M/S 85 Mustang
Old 09-09-2023, 02:12 PM   #5
Tom Goldman
Tom Goldman's Avatar
Liked 866 Times in 235 Posts
As was mentioned pedal ratio is critical .If the car originally had power brakes the ratio was only around 4 to 1 ,a ratio of 6 to 1 is considered ideal . also ,If you are only using discs on the front and retained the drums on the rear ,a master cylinder with a smaller bore will help.
On a disc /drum car I usually use a 1 3/32 bore master cylinder which wit the 6 to 1 pedal usually will yield around 1000 psi with reasonable pedal pressure.
Old 09-09-2023, 03:02 PM   #6
Gmirza
Liked 252 Times in 94 Posts
On my ‘71 Duster, I used an aluminum master cylinder that came on the Volare/Aspens. I have Strange fronts and stock 10” rear drums and factory proportioning valve also from Volare/Aspen. Never a problem stopping or holding the car. You could have a bad brake hose or a stuck caliper. Make sure too use the braided front brake hoses.
George Mirza
D/SA 1236
‘71 Duster 340
Gmirza is offline   Reply With Quote
Old 09-10-2023, 09:31 AM   #7
rebelrouser
Liked 8 Times in 3 Posts
Change the master cylinder bore to a smaller diameter, I usually use one inch. The smaller the bore of the master cylinder the more force at the wheels. Pascal's law is used to calculate a well balanced brake system.
14.3 Pascal’s Principle and Hydraulics | University Physics Volume 1 (lumenlearning.com)
rebelrouser is offline   Reply With Quote
Old 09-10-2023, 02:34 PM   #8
Dave Gantz
Liked 251 Times in 125 Posts
Don't forget the hose between the frame and the rear axle.
Old 09-16-2023, 12:24 PM   #9
Eman
Liked 133 Times in 76 Posts
If you really want to diagnose then you need a pressure gauge. As someone mentioned smaller bore MC means increased brake pressure but also less fluid volume per stroke. Larger bore less pressure but more volume. Rock hard pedal is good but you might have other problems. What condition are the back brakes, most assume everything is good if they aren't leaking but wheel cylinders freeze up, good pedal just no braking action.
Old 09-17-2023, 10:22 AM   #10
Greg Reimer 7376
Liked 705 Times in 219 Posts
Cool Re: poor braking
Many moons ago when I worked on cars for the general public, a customer brought in an early '70's Dodge van with a leaking master cylinder. We ordered out a new master, the parts house delivered it, we bench bled it and installed it, and all was fine except that you couldn't stop it without the brakes grabbing so hard it wanted to put you through the windshield. Calling the parts store and re ordering it and returning the first one revealed that the first one was for manual brakes, not power. It had a smaller bore and that caused there to be much more line pressure than the larger bore unit intended for the power unit.It may have been packaged wrong, who knows now. There is a decided difference between manual brakes and power assisted brakes as to the bore diameter.
