Old 09-06-2023, 01:30 PM   #1
Billy Nees
Default Re: So all of you Mopar guys!
Originally Posted by Steve Stasko View Post
The 41/40TE's are an interesting piece. There is an electric solenoid for each gear
Kinda like the trans in my Buick.
Billy Nees 1188 STK, SS
Old 09-06-2023, 02:02 PM   #2
Steve Stasko
Liked 276 Times in 144 Posts
I'd rather work on the trans in your Buick.
Old 09-06-2023, 02:09 PM   #3
Billy Nees
If there's an "electric solenoid for each gear", couldn't you rig up some kind of electric "shifter" to control what solenoids are engaged and dis-engaged and use it for gear selection and engagement? Just "brain-farting" here.
Old 09-07-2023, 07:16 AM   #4
Steve Stasko
I don't see why not. Would be interesting to see how people react to that. It would be similar to what they were using in Pro Stock during the 90's to control the Lenco solenoids I suppose.
I will add that I have had some in depth conversation with a Chrysler transmission engineer who didn't come out and directly say, but heavily implied that these transmissions were designed to fail.
Old 09-07-2023, 08:51 AM   #5
Billy Nees
Steve, I've had to deal with Powerglides and later, 200 Turbos. They were junk until Racers got their hands on them and fixed them. Now, they're in everything!
Maybe it's time for a Racer to step up and prove that "Chrysler transmission engineer" wrong.
Old 09-07-2023, 12:46 PM   #6
Liked 5,134 Times in 1,958 Posts
When we did the Monte Carlo, (3.4 V6 , 3300# , high 13's) I had decided to use a 125 C 3 speed, rather than the electronic OD.
The 125 started life in a 1980 4 cylinder Citation ( X car).
It never failed us at the track, but it tended to wear out final drives.
It was a bunch of work,.. having to fabricate mounts, a bracket for the TV cable ,and a custom right hand axle of the appropriate length.
If the earlier Mopar transaxle is close to a bolt -in deal, I'd go that way.
If not, the later one could probably be controlled by a series of switches. Clutch apply could be firmed up, I would think.
Light car , 4 cylinder shouldn't cause a lot of grief in that department.
Old 09-07-2023, 01:05 PM   #7
goinbroke2
Liked 404 Times in 158 Posts
As far as the solenoids go...(I'll try to be brief) Had a 93 f350 with a 7.3 and the e4od. Broke the planetary so I got another e4od out of a 98. Connectors etc all different.(6 planetary instead of 3 planetaries, much stronger too) I wired the solenoids (to test) and ran the wires up to the dash. Put the truck in drive and nothing. Depending on which switch (or series of switches) I went through all the gears as well as locking up the converter. Even went for a test drive.
So, yes it can be done.
Hassle? Yeah, a bank of 4 switches that you toggle through going down the track?...that would be interesting to say the least in competition!
Old 09-07-2023, 02:54 PM   #8
Steve Stickel
Steve Stickel's Avatar
Liked 50 Times in 23 Posts
Bill, are you tuning the Buick thru HP Tuners ? if so, should have some trans tables in there to "adjust" or turn off and on...
Steve Stickel
1161 Stk
1167 SS
Steve Stickel is online now   Reply With Quote
Old 09-07-2023, 03:02 PM   #9
Billy Nees
Yes, I'm using HP Tuners but it's not quite that simple with the Buick. The Cavalier is pretty simple.
Old 09-07-2023, 03:42 PM   #10
Doug Hoven
Liked 869 Times in 165 Posts
Both cars are relatively simple. The Cavalier sort of just does what it's told. The Buick seems to be a bit more rebellious, maybe even a bit vindictive at times.
1189 F/SA
Defunzalo Racing Enterprises
