Old 08-14-2023, 10:03 AM   #1
BRETV
Liked 776 Times in 199 Posts
Default Re: wanted - Ford Cylinder Heads
They were over the counter and marine applications. They were pre production GT40 heads before the GT40's came out in 93. The Explorer heads were all GT40P's.
Bret Velde
2003 ??/SA
BRETV is offline   Reply With Quote
Old 08-14-2023, 02:10 PM   #2
SBillinson
Liked 183 Times in 48 Posts
Bret Velde
2003 ??/SA
Bret,
Are these the same ports and chambers as the F1ZE-AA? I know that AA have GT40 cast on them, but otherwise I think they're identical to the BB. If that's true, it may be worth asking NHRA to approve them.
It's a suggestion which I'm sure won't sit well with some folks.
SS/BS 1921
SBillinson is offline   Reply With Quote
Old 08-14-2023, 06:52 PM   #3
BRETV
Originally Posted by SBillinson View Post
Bret,
They are the same head. I mentioned the same idea to Marty. We have done that in the past.
Bret Velde
2003 ??/SA
Old 08-16-2023, 12:10 PM   #4
Marty Buth
Liked 232 Times in 39 Posts
Bret Velde
2003 ??/SA
Someone told me that the F1ZE-AA head has larger valves than the F1ZE-B head.
Marty Buth 3657 STK
Marty Buth is offline   Reply With Quote
Old 08-16-2023, 02:01 PM   #5
SBillinson
The -AA come with 1.84/1.54 valves.
The throats on a set I have measured 1.64"/1.27", which would give you a 92% intake throat and a 87.5% exhaust throat when using 1.780"/1.450' valves.
In other words, you'd need to change the intake seats because the throat's too big. A 92% throat will work, but 88%-90% is where you want to be for a stocker.
You'd also have to sink the exhaust valve, but there's enough material on the seats to keep the throat at 88-89%. Depending on how much you have to sink them, you may be better off replacing all seats in the heads.
SS/BS 1921
Old 08-18-2023, 09:30 AM   #6
BRETV
The F1ZE-B head has 1.84/1.54 also. That's the head I had my 92 Mustang SS/LA car.
Bret Velde
2003 ??/SA
Old 08-18-2023, 09:50 AM   #7
Marty Buth
Bret Velde
2003 ??/SA
Thanks Bret!
Marty Buth 3657 STK
Old 08-18-2023, 09:58 AM   #8
Marty Buth
Bret, I am confused. The F1ZE-B is an approved cylinder head, but the blue print spec. shows valve size to be 1.782"
Marty Buth 3657 STK
