#11 | |
Liked 988 Times in 272 Posts
lowering the classes .4 will kill 25% of the cars if you look in Nitro Joes stats Getting rid of most heads-up races will drive more racers away and turn it into bracket race. If you do a review and add HP at the end of the year, you still have AFHS, and if you get rid of Heads up runs you don't need AFHS. I'm surprised you didn't get rid of qualifying the way its run now. Why get rid of fuel regulations, oh yeah, its a bracket race under you're new rules. Good luck on increased prize money. Some people love national events, and having grade points keep those who want them going to divisionals, dropping nationals and getting rid of grade points will do nothing to help the classes. Helping reduce travel to win a championship will not help either. you can race your local bracket track, go to the bracket finals and still be a champion. What don't you like about the contingency program? did you not get paid? I have received over 1500.00 in contingency this year and am only waiting for a couple still, and only 1 I have had no communication with. I think if the Associations wanted to be together, they would do it. Thats NHRA racing to fall under one sanctioning body. If you didn't want to get flamed or trolled on your post, don't post it. everything on this group is up for discussion.
Duane Hoven 1342 SS/GT |
#12 |
Are we still on the roller cams? have you not been able to get Schubecks or tool steel lifters and a billet cam?
#13 |
edited
#14 | |
Liked 776 Times in 199 Posts
Bret Velde 2003 ??/SA |
#15 |
Liked 704 Times in 281 Posts
There was a stick Camaro out at Speedworld that would destroy the starting line. We would prep and start the event and have several pairs run down track. Good foundation on track then this Camaro would come up and I believe a 9 inch tire that would just remove a 2 foot long section of rubber right down to the concrete. Every pass and every event we would have to address the starting line after him. Not sure if problem was him or me.
#16 | |
Liked 7,682 Times in 1,730 Posts
They have become too specialized period! The vast majority are nothing more than small-tired Comp Cars.
#17 | |
Liked 183 Times in 54 Posts
that is until here come the headers ,and on from there
John Ancona 717 STK / SS |
#18 |
Liked 43 Times in 14 Posts
"BTW - IF YOU WANT TO BE TAKEN SERIOUSLY USE YOUR GIVEN REAL NAME."
Modified the post and my signature. Thanks for the tip.
Dave White NHRA Stock/SS 606 |
#19 |
Liked 230 Times in 106 Posts
Guess we are. It seems We could find an answer to why only obsolete Schubecks, or $2000+ tool steels are legal in older cars but a roller ain't.
#20 |
Liked 826 Times in 163 Posts
I have no dog in this fight, being that the fastest I’ve gone with my stocker is .60 under(so far), but I have a set of $250 lifters in my engine, a cast camshaft that is plenty big, and not all that much spring pressure, and everything seems to be ok in my valve train. The only thing adding roller cams to all cars in stock is give an advantage to racers that can afford another probably at least $2,000 in a roller cam, lifters, and valve springs to match. And don’t be tempted to buy cheap roller lifers. They can cause similar catastrophic events as a schubeck that experienced valve float one too many times.
1189 F/SA Defunzalo Racing Enterprises Last edited by Doug Hoven; 08-10-2023 at 04:31 PM. |
