#1 | |
Liked 520 Times in 176 Posts
The rear tail lights (Nova Body ) are a little wider for the 1970 - 72 body. The front bumper has bigger turn signal lights that are amber instead of kinda clear from the 1968-69 body. The 1968 has the ignition key on the dash, 1969 -72 has the ignition key in the steering column. The 1968 has the short marker lights front and back. The 1969 has the same as 68 short rear marker light with a longer chrome bezel showing engine cubic inch's. the 1970 -72 has the long side marker lights. So there's some more food for thought, Do I think NHRA cares anymore about marker lights, I seriously doubt it at this point, but I'd make sure that the engine combination has all the correct casting numbers for its application. With the 1969 body you can run just about every engine that Chevrolet had in its line up except for the 396/325 engine. Also no 427's, but a 1970 you can get the 402/ 375 HP engine and that's a good engine combo. What you are considering is the very reason I went with the Nova body some 40 + years ago. Versatility in the same body platform, one draw back is putting a good size 9x30x15 tire under there is a little challenging, between back spacing and a little creativity you can make it happen, not impossible. Most of the stuff that fits a Camaro will bolt on to the Nova, without the Camaro price tag. So, I hope this expands you horizons some - Have a Good Day and a Safe 4th of July. Respectfully, Henry Kunz 1534 H/SA Nova |
Liked 2,361 Times in 558 Posts
Didn't they toss a Nova for claiming the wrong body a while back?
Daren Poole-Adams NHRA Stock/SS 2007 |
Liked 162 Times in 45 Posts
You are correct. I believe it was the chap from Europe that bought a west coast car with I believe a 402/375 that would fit AA if he claimed the correct year but he didn’t. Someone caught his mistake and he got tossed. There are a lot of nice combos for that Nova body style. And the car can get very light.
#4 | |
Liked 226 Times in 97 Posts
But then someone else took that to the next step to note that there was no combo that fit AA/SA for the model year that was claimed.
Tony Leonard S/ST 56 S/C 53 |
#5 | |
Liked 526 Times in 76 Posts
7350 Stock Eliminator Quite possibly the only member to REDLIGHT their join date ![]() |
