#21 |
Liked 129 Times in 53 Posts
I would not like to go there for a number of reasons :
1. It was not my problem so I never heard it from the chassie builder myself 2, Since it was not my car I was not interested enough to maybe remember what I heard correctly if what I heard now was correct! 3. This was in the beginning of wider Radials so "the problem" has most likely moved around between brands since then with moving factory's and outsourcing etc. also it could have to do with what car or combination you have? only a reputable chassie builder would probably gathered enough info to know about this. Free info is what all expect and often get on the internet, and it's usually worth what you pay = nothing ![]() Well Ok...here's the free advice : If I remember it correctly I think he was told to get Mickey's ![]()
Stop global whining |
#22 |
Talked to the Goodyear representative and he said to raise the front tire pressure to 40psi and try that.
#23 |
And does Mickey Thompson even make a 14” wide radial?
#24 | |
Liked 127 Times in 27 Posts
