Old 06-19-2023, 07:36 PM   #1
Default Re: SFI flexplate mandatory in all v8s Jan 2024
Originally Posted by Duane Eiskant II View Post
Mark, Nope haven't seen a 301 crank. Just adding thoughts to NHRA's thinking. Since this is opening a rabbit hole no body wants to go down
Okay, neither have a lot of guys here, I suspect.
It only has two opposing counterweights, front and rear.
The flex has a big balance weight on it. I wouldn't want to fool around with that bit of Pontiac engineering ;-)
TCI makes an SFI for the 400, which is the same except they are internally balanced.
This brings us to modifying an approved part. I see that this would have to be re-done every three years too. It's not gonna pass re-cert.
I seem to remember hearing that the perp in the Texas was invited to the barn for a look see. Now supposing one comes apart next year, you can bet it's coming apart too.
If they happen to find a modified SFI unit that failed, who do you suppose is going to have to pay that fine?
There are at least three of those 301 cars out there. These are 6 grand in the lights, max combos. What are they supposed to do ?
As my lawyer would say "arbitrary and capricious"
Old 06-20-2023, 10:14 AM   #2
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
I agree Mark. Both of my convertors when ordered from ATI were done with the 3/8 bolt size just to avoid this.
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
