Old 05-24-2023, 07:28 PM   #1
RJ Sledge
Liked 288 Times in 90 Posts
Default Re: 1964 Comet Wagon R/SA 289 Precision Shifter Joel's Hoos
My bad, just pulled up 2020 Belle Rose divisional race Stock Qualifying and Jacob Wilson ran a 12.572 in N/SA which is 13.00 and ran .42 under.
Thanks John
RJ
RJ Sledge is offline   Reply With Quote
Old 05-25-2023, 08:14 AM   #2
Joe Strunk
Joe Strunk's Avatar
Liked 5 Times in 3 Posts
RJ,
Is this Rob Torens old car?
If so, I thought Dick had it set up to run SS??
Thanx!
[SIGPIC][/SIGPIC]
SS/MA 2890
Anderson & Toren Comet
Joe Strunk is offline   Reply With Quote
Old 05-25-2023, 05:49 PM   #3
RJ Sledge
Joe
Correct Joe
I believe I talked to your son about it last year, put the Stock Elim 289 back in it and swapped out the alum driveshaft and air shifter so it’s back to Stocker status.
Wilwood brakes, Mark Williams axles, new Hoosier tires front and back, fuel cell, Precision Shifter, MSD, New Kirkey PT#41900 18” wide pro series with upholstery, C/E shocks, Cal/Tracs with split mono leafs, 5.29 with 35 spline spool, Strange center section, Painless fused switch panel, swing out bar, two step button brake pedal, Derby City front fender cover etc.
Take care
RJ
Old 05-28-2023, 11:35 AM   #4
Tim Ellis
Liked 7 Times in 6 Posts
RJ can you send me pictures? I believe you did before, but I must have emptied my inbox. Thanks
Tim Ellis is offline   Reply With Quote
Old 06-23-2023, 08:56 PM   #5
michael mercer
Liked 2 Times in 2 Posts
Doesn't this car run either n/sa or o/sa ?
michael mercer is offline   Reply With Quote
Old 09-01-2023, 09:01 PM   #6
RJ Sledge
Car is sold
Thanks Class Racer!
RJ
