Old 05-05-2023, 09:33 PM   #1
David Lee
Liked 346 Times in 126 Posts
Default Re: Rear housing Question
Originally Posted by bigshow2966 View Post
I want an 8-3/4 because I have a bunch of crnter sections in various ratios.
Thanks for all the replies!
what combo are you going to run?
Old 05-06-2023, 08:40 AM   #2
PENTAFAN
Bigshow you have a PM.
PENTAFAN is offline   Reply With Quote
Old 05-06-2023, 08:45 AM   #3
bigshow2966
Liked 181 Times in 56 Posts
V/SA 225 2 bbl. I think I have enough stuff laying around I can run the index maybe.
I turn 65 in 3 weeks. It's going to be my retirement project.
bigshow2966 is offline   Reply With Quote
Old 05-06-2023, 02:47 PM   #4
GTX JOHN
You could even run the 8 1/4 in that if you could find
the needed parts.
My 80 Mirada 318 O/SA ran a 8 1/4 forever without breakage!
John Irving
741 Stock
741 Super Stock
Old 05-06-2023, 05:12 PM   #5
David Lee
congrats on your retirement. i have tons of family in chi town
when i looked at this combo and the 8.25 rear. the deepest gear was a 4:88
Old 05-06-2023, 07:22 PM   #6
Adger Smith
Liked 880 Times in 311 Posts
With the power level and weight you will have I would consider a 8 3/4 Detroit locker. The Locker for the 489 case fits up to 4.56 gears.
Most of the time a Locker will have a spool beat on MPH. 30 spline gives you plenty of choices in Stock or stock re-splined axels That
are budget friendly and plenty strong. If you do go all out on axels a 30 spline has a weight advantage.
I'm not sure, but you might even find a gun drilled 30 is available.
.02 for free
Adger Smith (Former SS)
Old 05-07-2023, 12:33 AM   #7
bigshow2966
I had thought about the 8-1/4, but then I would be back to starting at 0, I have no parts for one.
This is kinda going to be a "dime rocket" but more likely a "50 cent rocket".
Thanks for all the replies.
Old 05-07-2023, 03:13 AM   #8
David Lee
if you are going to use a spool, measure what axles lengths you require. i may have a free set of aftermarket axles
