Old 04-21-2023, 01:42 PM   #1
Race Clean
Liked 129 Times in 53 Posts
Default Re: 9" vs 12 bolt.
A buddy used one of those 12-bolt drop out pieces many moons ago in a SS application.
He used up gears like crazy, that lead me to believe the performance advantage aspect somewhat disappeared, it was a heavy car
and the Aluminum 3'd member maybe was flexing?
Stop global whining
Race Clean is offline   Reply With Quote
Old 04-21-2023, 03:39 PM   #2
Ralph A Powell
Liked 226 Times in 137 Posts
A good test would be to a loss test on the 9” nodular vs the High strength steel that Strange manufactures for Ford NASCAR program the HS case is 3 lbs lighter that nodular and about 30 % stiffer. According to Bob Stange so it hold everything in place. I don’t believe an aluminum case is as strong as the Ford nodular with the modified tail bearing, the Daytona pinion support and a load bolt to support the ring gear.
