#71 |
Liked 10,769 Times in 2,238 Posts
If a combo has two runs if 1.20 under it will take 20 runs of .800 under to bring the average to .836 under. So all is not lost maybe just a few heads up races.
#72 |
Liked 647 Times in 140 Posts
Robin Lawrence said THIS!!!
There will always be racers to work harder, spend more money and or time to be fast. So True! Mike McMahan 2543 G/SA |
#73 |
Liked 7,783 Times in 1,743 Posts
only to "have" to slow their stuff down and complain about it.
#74 |
This should be going on much more often than it does.
#75 |
Liked 37 Times in 8 Posts
NHRA did lower the indexes back in the early 90's, I believe, by 2 or 3 tenths. But many complaints reversed that decision as I recall. I talked to several stock racers this weekend in Pheonix and lowering the indexes was a very popular answer to this whole problem. The slowest car in stock was -35 under the index. That would have left him with a .15 second cushion. As a racer, I always enjoyed watching qualifying. Not anymore, almost every car was running 70 to 90 under. That ruined watching qualifying for me. It's not 1977 when I started in Stock. Even my old home built car will run -50 under the index. Times change, so should the indexes.
#76 |
Liked 586 Times in 162 Posts
Lowering the indexes across the board does absolutely nothing. It changes the numeric values is all that does. A soft combo is still a soft combo but instead of it being a -1.30+ capable car it becomes a -1.00 second car as number 1 Qualifier at Indy let's say.
That is why NHRA uses the AHFS which is flawed obviously but has it's merits. It's the manipulation of it that makes it ineffective. Lowering the indexes across the board just puts the number at a different value across the same board. It's like cutting a foot off the top of your blanket and sewing it on the bottom and thinking you shortened your blanket. |
#77 | |
#78 |
I would enjoy the reinstatement of the qualifying points with a twist. The twist would be ten qualifying points equals a grade point. It would be great to have the qualifying points included in the points chase. That will make some interesting runs later in the year.
This is about performance Last edited by Larry Hill; 03-27-2023 at 11:10 AM. |
#79 | |
Liked 449 Times in 98 Posts
Agree, there needs to be more incentives to go fast for the AHFS to work. The way it is currently, NHRA has incentivized .70 under runs. Bobby Fazio had a nice list of such incentives. The SRAC should take up consideration of a performance incentive program that if widely supported by currently active racers, should be recommended to NHRA. |
#80 |
Believe Qualifying #1-5 should be recognized (either as average highest position based on 5-8 races or even at the individual race) with awards ($) but not count toward the points chase. In that scenario is it likely that D'Agnolo wouldn’t be carrying the Number 1 on his car? Probably. Would D'Agnolo, Kevin Helms or Jody Lang need to change classes and acquire or build the best combo in order to prove they worthiness to wear #1? Would hate to see the deepest pockets have an advantage over the best drivers.
