Old 03-15-2023, 02:56 PM   #1
wdrevojr38
wdrevojr38's Avatar
Liked 51 Times in 9 Posts
Default Re: Factory Stock Showdown
I was wondering about the rake on Joe’s car but when I saw how loose he got down track in the semifinals one has to wonder. With the MPH he’s running a “parity adjustment”‘might be coming.
The mph that car is running is a monster number for that class which represents a lot of horsepower……..hmmm! That ‘nose down’ attitude’ for that car keeps frontal air from getting up in the engine compartment which would help it’s mph number a little bit. That car’s ‘nose down’ effect is similar to the optional front air dam (with rear spoiler) available on the ‘67 - ‘69 Camaros which also kept frontal air from doing the same thing.
wdrevojr38 is offline   Reply With Quote
Old 03-15-2023, 07:39 PM   #2
jimmyparker
Liked 309 Times in 88 Posts
I understand the drag radial group checks the heat on the u-joints after every run and replaces every three or four runs, evidently the severe chassis separation is causing drive shaft angles to be out enough to warrant this.
jimmyparker is offline   Reply With Quote
