#11 |
Liked 491 Times in 229 Posts
How loose did he get in the semi ?
Jake Biermann |
#12 |
Liked 5 Times in 4 Posts
These cars are in fact a small tire radial car....Just a 30x9 instead of 28. I see some of the class were quicker than Welch's, all increments until the 660, then his car really started moving.
#13 |
Liked 51 Times in 9 Posts
The mph that car is running is a monster number for that class which represents a lot of horsepower……..hmmm! That ‘nose down’ attitude’ for that car keeps frontal air from getting up in the engine compartment which would help it’s mph number a little bit. That car’s ‘nose down’ effect is similar to the optional front air dam (with rear spoiler) available on the ‘67 - ‘69 Camaros which also kept frontal air from doing the same thing.
#14 |
Liked 309 Times in 88 Posts
I understand the drag radial group checks the heat on the u-joints after every run and replaces every three or four runs, evidently the severe chassis separation is causing drive shaft angles to be out enough to warrant this.
#15 |
Liked 370 Times in 101 Posts
He did get disqualified @ Indy 2018 after he ran the first 7 second run, his DQ had to do with adjustable lower rear control arms which weren't allowed, the rod ends and lock nuts were welded, and had competed @ several earlier NHRA events. Welch's car spends lots of time at Mike Moran's shop in Michigan.
Jerry Heath I/S '93 Cobra FS/J 2010 Mustang "Ebay CJ" Last edited by JHeath; 03-15-2023 at 08:20 PM. Reason: add |
