Liked 7,938 Times in 1,519 Posts
C’mon Charley, excessive braking…it’s the usual suspects. You talk to the majority of them on the phone every week. Occasionally the DD actually has the ballz to DQ them. A week or two passes and then they get brake happy all over again. Unlike the whiny azz, chicken chits that believe BLINDERS are the work of the devil , I don’t have a problem with anyone that HOLDS or DIALS SOFT. If that is your program then more power to you. To each their own . My only advice when you are racing me, PLEASE stay in your lane ….
Liked 68 Times in 41 Posts
I would assume you get one warning for the first time then the boot for the second time in the same event.That's what it looked like at No problem race a few weeks ago.
1231 FS/D Drag Pak 1231 E/SA 71 Demon Kelly MacKay |
Liked 38 Times in 13 Posts
The last I heard was when there is smoke from the front tires it's excessive braking
Larry Peterson Stk: 6261 B/SA ![]() |
Liked 4 Times in 3 Posts
But according to the rule (that appears very clear in the NHRA rule book) you HAVE TO come into contact with something or cross the centerline even after the finish (if it was judged as excessive braking the cause) to be disqualified...It says nothing about tire smoke, stunt driving and etc.
Im not saying the rule is right or wrong but the way it reads that unless you hit something you're good? |
Liked 169 Times in 53 Posts
Excessive braking: Smoke coming from front tires; easy to see, easy to enforce. Common sense rulemaking.Probably why it's not in rule book.
Bill Bogues 4696 STK |
Liked 476 Times in 117 Posts
it was IHRA but scooter once most eloquently told me "i dont care if your rings go away if i see smoke at the finish line your *** is outta here"
i most certainly understood ![]() '
Jack McCarthy 3609 STK "the Captain" |
Liked 704 Times in 281 Posts
Tires smoking is tires sliding on surface. Sliding tires are out of control. Out of control is on the edge of crashing. Sounds like an accident waiting to happen. At a big bracket race at Speedworld I was race director and I expressed my feelings that making smoke your out. I told the racers it up to them how to handle it. Majority wanted to be tossed for smoke.
During elims a car made smoke and I tossed them. They came to me and wanted to show me the frozen caliper on car. Sure enough 1 was frozen and tire would not turn by hand. I reinstated them and they did replace caliper. |
