Old 02-27-2023, 03:01 PM   #1
Kdw1403
Liked 68 Times in 22 Posts
Default Did the new rules effect anyone
What’s the feed back? Looks like several people at the div 4 race at no problem went well over a second under more than once. Does that trigger a review at the end of the year? Did anybody race any differently than they used to?
Kdw1403 is offline   Reply With Quote
Old 02-27-2023, 05:55 PM   #2
tstickff
tstickff's Avatar
Liked 561 Times in 138 Posts
Default Re: Did the new rules effect anyone
Looks like a certain 305 transplant didn’t get the memo, I assume HP is on the agenda for us now…..
Tim Stickles
Tim Stickles
tstickff is offline   Reply With Quote
Old 02-27-2023, 09:36 PM   #3
Rob Petrie E395
Liked 216 Times in 77 Posts
The way I understand it. Is two runs more than one second under during the entire season triggers a review at the end of the year. The review will consist of averaging all runs for the year that are .650 under or faster. After they average all those runs. If the average is .850 under the index hp will be added. Is this not how it works?
Old 02-27-2023, 10:58 PM   #4
James Perrone
Liked 1,863 Times in 435 Posts
Hit List 2023 on notice
350/255. Camaro
396/375 camaro
327/275 67 nova. Stick shift
305/ Malibu
james perrone 1290 STK
Old 02-27-2023, 11:42 PM   #5
GTS340
Liked 1,355 Times in 414 Posts
Until you actually start adding in your runs for average. Those less than .65 under runs not counting will surely hurt. . Still early to see what happens when mineshaft conditions come into play.
On the other change. Pat Cvengros was leading the staging lanes with a note pad. A couple folks were asked to remove different things here and there.
Paul Haszlauer
Old 02-27-2023, 11:42 PM   #6
Marty Rinehart Jr
Marty Rinehart Jr's Avatar
Location: Rineharts Performance Race Cars, Thomasville,PA
Liked 333 Times in 75 Posts
Yes. The 2) 1.00 runs trigger the .85 under average. But the amount of HP added is not off of the average, it goes off of the fastest run made of the combination. So the hp will be significantly higher from the fastest run, than the average of the runs.
Yes, it’s confusing to most and most really don’t understand how it really works.
Marty Rinehart Jr
1125 SS STK SG SC SST
Marty Rinehart Jr is offline   Reply With Quote
Old 02-27-2023, 11:53 PM   #7
GTS340
Yes, it’s confusing to most and most really don’t understand how it really works.[/QUOTE]
You mean like the 360 drag pak is on point to get 12hp at this rate and the 396/375 might absorb 10hp more. Ouch!
Paul
Old 02-28-2023, 12:37 AM   #8
Tom Meyer
Liked 354 Times in 120 Posts
Will all class elems runs this weekend count? Will the ram air F body LS1 hp change and the flat hood stay the same? Tom
Tom Meyer 5240 SS Stock ???
Old 02-28-2023, 12:57 AM   #9
Brent Kopejtka
Liked 48 Times in 22 Posts
Thanks for clarification I thought it was where average ended up. Big difference!
Brent Kopejtka is offline   Reply With Quote
Old 02-28-2023, 01:12 AM   #10
GUMP
Liked 2,361 Times in 558 Posts
It looks like a few people will get burned...
Daren Poole-Adams
NHRA Stock/SS 2007
GUMP is online now   Reply With Quote
