Old 02-15-2023, 01:37 AM   #11
TBear5033
Liked 112 Times in 16 Posts
Default Re: Gainesville Stock spot open
Originally Posted by tstickff View Post
I understand that, I initially was only going to run SS, the option of entering stock came up so I figured why not, it’s not a huge deal if I run stock also I was just venting about the dumb process, why count me out for 12 grade points when they don’t technically even count past 8 GP? You would think if they only counted 8, that would leave me with 4 to enter another class at the 4 GP mark, like I said it’s not a huge deal it just makes no sense to me
I ran into the same problem a year ago - I had 15 combined grade points - 3 in SS and 13 in stk... how that added up to 15 must be some sort of Glendora math... Made the mistake of entering SS first and missed the little popup window that said I would use ALL grade points to make this entry. When I asked about it, the explanation made NO sense and the person explaining it me agreed but said that the Division Directors wanted it to work this way. Go figure!
TBear5033 is offline   Reply With Quote
Old 02-15-2023, 10:40 AM   #12
Lenny5160_v2
Lenny5160_v2's Avatar
Liked 225 Times in 96 Posts
Honestly it’s no big deal if I don’t get in for stock...
I don't think this is an "if" situation. It sounds like all of your grade points are already used, so you can't make another entry even if there are open spots at Grade 1.
The transformation to the old Malibu is amazing, by the way. Great work!
Tony Leonard
S/ST 56
S/C 53
Lenny5160_v2 is offline   Reply With Quote
Old 02-15-2023, 11:53 AM   #13
tstickff
tstickff's Avatar
Liked 561 Times in 138 Posts
I’m pretty sure when it gets to the Monday of the race, whatever that last day is if there is an opening I could enter basically as a zero GP, but I could be wrong, I don’t see there being anymore openings so that’s fine.
And thank you the car has been a work in progress lol
Tim Stickles
tstickff is offline   Reply With Quote
Old 02-15-2023, 12:56 PM   #14
Tim, Last time we were able to do such a thing, the site wouldn't even let you go any further without one GP. You needed at least one to get in the door.
I seem to remember before that, you would need the amount of GP's that it filled at.
Old 02-15-2023, 08:26 PM   #15
Keith Bennett
Keith Bennett's Avatar
Liked 70 Times in 36 Posts
Send a message via MSN to Keith Bennett
Tim,
You should have 2 grade points now after the Orlando race.
Keith
Keith A/S 2990/Terri A/SA 2991
"Imagine what you'd attempt, if you knew you could not fail!"
Keith Bennett is offline   Reply With Quote
