Liked 225 Times in 30 Posts
1- Powerglide,1.96 ratio, trans brake, roller tail housing
new yoke for 1350 joint,no runs since freshen up. $1250.00 1 -used B&M PRO Stick with cable. $180.00 9- New Venolia Pistons,327 superstock, 4.061dia. .031x3/16 ring groove,.875x2.500 pins included. $750.00 8 - New Eagle H-beam rods, CRS6250b3d, 6.250long 2.225 big end, .927 pin end. $ 300.00 1- used Moroso Aluminum SBC Superstock pan,12" wide rear sump 8" deep, kick out . $550.00 New 875.2.250 Pins $90.00set New .875x2.250 Pins $90.00 set New MSD # 85551 Chevy Distributor $275.00 New MSD #6425 Digital AL-6 ignition $250.00 1-set Performace Welding Merge collectors, 2 1/8 2.5 choke 3' exit,14' in long,o-2 bungs, powder coated $ 275.00 2- 041 bare heads $200.00 8-New SBC Lunati roller rockers, 1.6 ratio, 7/16 stud, $125.00 1-pair #840 rectangle port BBC heads, no grinding,bare, $800.00 1-67 Camaro steering wheel, black ,nice $275.00 you pay shipping, 760-630-9094 |
Liked 706 Times in 283 Posts
Greg what model or name for the 8 Lunati rockers? Voodoos?
PM sent
Liked 880 Times in 311 Posts
1.96 PG
is that the lt weight 6 cyl carrier or the 1.76 V-8 style carrier? Helical or St. cut teeth T-brake?
Adger Smith (Former SS) |
Greg, would you ship trans?
