Old 01-21-2023, 09:20 AM   #1
Liked 10,769 Times in 2,238 Posts
Default Replacing the top on damaged hardtop car
Has anybody have any experience?
Old 01-21-2023, 12:19 PM   #2
Liked 5,129 Times in 1,956 Posts
Default Re: Replacing the top on damaged hardtop car
Yes.
One of the cars I built (it's still out there, so I won't be specific) had to have the top replaced.
When I was stripping it down, I found that the top had been brazed on (!) previously.
Figuring that wasn't a good idea with a torquey stick shift car, I had to fix it.
I was given a donor body from a similar line of GM cars. I cut the roof off mine, below the brazing, and then mig welded the new top on at a point below the previous splice.
I though about taking about an inch out of the top height while I was at it, but of course that wouldn't have been legal ;-)
What's going on with you, Larry?
Old 01-21-2023, 07:18 PM   #3
Liked 1,863 Times in 422 Posts
Larry,
The guy you want to talk to is Chris Avaritt, at CrossThread Customs. He's on these boards as "Crisco", he worked for Kevin Cradduck at NitroPlate. Best paint and body man you'll find.Period.
Old 01-22-2023, 12:51 AM   #4
Mike Gray
Mike Gray's Avatar
Liked 692 Times in 200 Posts
Yes.
He’s probably trying to figure out how to add a couple of inches.😁
Mike 7570 A/SA
Old 01-22-2023, 02:40 AM   #5
tavirace
Liked 18 Times in 13 Posts
Yes.
I can't speak for all cars but I worked building Toyota Corollas for a number of years. I know up till 2001 all the roofs were spot welded in place and then brazed on, I wouldn't have been suprised to see it.
tavirace is offline   Reply With Quote
Old 01-22-2023, 08:15 AM   #6
Looking at a car with a top that’s bad and was trying to figure out what made dollars and cents.
Thanks for the information.
Old 01-23-2023, 09:14 AM   #7
Crisco
Liked 46 Times in 21 Posts
Yes it can be done. Also, it depends on if any company reproduces the roof skin for the car. What kind of car are you looking at?
Give me a call at the shop if you have any questions.
Chris Avaritt
615-431-2286
Crisco is offline   Reply With Quote
Old 01-23-2023, 11:32 AM   #8
GUMP
Liked 2,354 Times in 554 Posts
We switched a Firebird from T-tops to a hardtop. It really wasn't that bad. Finding NOS parts was probably the hardest part.
Daren Poole-Adams
NHRA Stock/SS 2007
Old 01-24-2023, 02:31 PM   #9
Todd Gross
Liked 54 Times in 24 Posts
Larry, are you speaking of your Drag Pak? If so, I can help you with what you need to know. I replaced the Roof skin on mine.It was pretty straight forward.
Todd Gross
3323 FS/E,F
Todd Gross is offline   Reply With Quote
Old 01-25-2023, 07:43 AM   #10
Nostalgia SS car / chase car for NMCA. I believe we can go 13.00 through the muffler.
