#11 | |
Liked 974 Times in 310 Posts
#12 |
Liked 249 Times in 48 Posts
Remember the old days when you ran under the record, backed it up, were tore down and then wrote your accomplishment on the side of the car? Your feat was then validated in every issue of ND. Made you a BMF. Sweet memories of days of old. Pete
#13 |
Liked 776 Times in 199 Posts
They SHOULD at least post them in the National Dragster. Couldn't wait to go to the back and see what the new records were.
Bret Velde 2003 ??/SA |
#14 |
Liked 2,741 Times in 967 Posts
It used to be a "Badge of Honor".
#15 |
Why do some classes say minimum?
#16 |
Liked 312 Times in 175 Posts
#17 |
Liked 755 Times in 213 Posts
Just a little correction/add-on: Minimum are rather set at 5 tenths under the index instead of minimum number
#18 |
Liked 35 Times in 11 Posts
#19 |
Liked 535 Times in 110 Posts
That is correct, you must go at least .5 under the class minimum.
Jim Kaekel 3836 STK |
#20 |
The minimum that is posted is already .5 under the index. You would only have to exceed that to set a record.
