#61 |
Liked 1,345 Times in 410 Posts
Is there an advantage using one? Been doing this for 50yrs watching a full tree and holding the rpm on a footbrake at the same time without a two-step. I can watch one bulb come on. What's the big deal? Of course I can't string .000 lights like the last few races last year either like some. I'm sure they'll be able to adapt if blinders were used.
Paul Haszlauer 79 C/SA |
#62 |
Liked 7,783 Times in 1,743 Posts
When are we going to do something about the "data loggers can't be hooked to the ignition box" rule? Or how about the "no driveshaft sensors" rule?
#63 |
I searched the Rule Book and I couldn't find a Sandbagging statement, but I clearly remember seeing it in past issues.
Just a note, much of the current Rule Book was written by lawyers. |
#64 |
Liked 8,011 Times in 1,526 Posts
Thanks Frank, after being interrogated by Mr. Gary I was questioning my sanity ….LOL. ….
#65 |
#66 | |
Maybe we could get stuff like this fixed if we could get the NHRA Techs to "take off their blinders".
Billy Nees 1188 STK, SS I'm not spending 100K to win 2K Last edited by Billy Nees; 01-20-2023 at 09:49 AM. |
#67 |
Liked 867 Times in 165 Posts
One problem I foresee with trying to enforce this, is what are you going to do with all of the EFI guys that use their ECU to control their MSD ignition. Specifically, one of the more, relatively speaking, "dumb" MSD boxes such as a 6al, 7al-1,2,etc. I understand the things that can be done if someone were to be using a GRID, but these other boxes have no internal hardware of their own to do any sort of "witchcraft" during a run. It would be relatively straight forward to police datalogging with a racepak. If the sd card isn't in it, and no computer is plugged in to the COM port, no data is able to be recorded. EFI however stores data logs within the ECU, so that could be a tricky one.
1189 F/SA Defunzalo Racing Enterprises |
#68 | |
#69 | |
Liked 502 Times in 130 Posts
And of course at night, it gets even better, for the Copo/Cobra Jet......same problem, now theres a explosion of light going on behind that blinder, takes some mad focus skills to rip a 00 light under those circumstances......advantage non-blinder heads up runs......blinder could help you be safer assuming you have the faster car....advantage blinder for fast car, no advantage if your the slower car, unless you need the safety net. normal racing.....blinding can help you simplify the process, and just see light and react to light, helps add that additional delay(assuming your vehicle can react.....blinding with a T/SA gremlin would be challenging for most) Advantage blinding.......but if your late, your dead late..... The sun visor of course can be used to legally block the tree, but its not going to be as consistent as a roll cage mounted blinder.......advantage non-blinder I am of the opinion that it doesn't really matter. You have to consistently react to the flash, it would be truly brutal for many if they REQUIRED blinding/blocking! Eric
Eric Merryfield 1883 STK |
#70 |
If it was 1999, I would definitely consider running the factory ECU in a 5.0 mustang or a 3rd and 4th gen firebird, but you pretty much need a time machine in order to get the software and a computer that will run the software. And those early handheld programmers have mostly faded away into the pages of history. The factory stock cars are a tough one too. I don't know about all of the years, but the Cobra Jet mustangs were using essentially a tuned up street mustang ECU. I believe the COPOs and Drag Packs use aftermarket ECUs from the factory, so that sort of makes the OEM ECU rule a moot point in a way for them.
