Liked 2 Times in 2 Posts
I need help, we have a 68 Camaro bracket car with brodix heads. They have stahl pattern for the header flange. The current headers are shot and the closest replacement header doesn't fit dads budget.
Is there a adapter plate from stahl to oem pattern? Thanks, John Beasaw |
Liked 90 Times in 52 Posts
would the Moroso Header flange kit 67650 not work ?
Liked 82 Times in 23 Posts
I have a pair of Stahl plates,maybe you could use them in reverse?
Text me for a pic 1-613-286-5760 Dom |
Liked 9 Times in 4 Posts
If the Brodix heads are spread port on the two center exhaust ports you can not go to std exhaust flange headers. You can maybe make them fit but the tube to port alignment is way off. Have you checked Schoenfeild headers?
Liked 7,768 Times in 1,741 Posts
Have you called ACP? The old Stahl?
The brodix head may be the bigger issue, i will be looking into that. ACP does offer a header but a bit too pricey.
Thanks! John |
