#11 |
Liked 10,798 Times in 2,244 Posts
I don’t remember how much but it was way cheaper than a crank, pistons, rings, cam, block, lifters, oil pump, and Band-Aid’s. Those shards of metal go right through those blue gloves.
#12 |
Liked 1,603 Times in 583 Posts
#13 |
Liked 48 Times in 24 Posts
So i guess you racers were not told by your eng.builder what they paid for coated lifters.
i looked on trends price sheet, they were getting $1408 before the shortages and now i am told close to $2000, but since other people are posting company websites i will post my suggestion too ,might even be better than dlc -- go to forcealtered.com
Rocketmancoatings |
#14 | |
#15 |
Liked 6 Times in 6 Posts
Tell us a little about them . Do they have to rotate? Can they be used on multiple cams ? Do they have to be refaced ? Im talking the johnsons not the tool steel.
#16 |
Liked 695 Times in 201 Posts
#17 | |
Administrator
Liked 587 Times in 35 Posts
ProfessorRock has permission to post there services.
Administrator Class Racer.com |
#18 | |
Liked 136 Times in 49 Posts
I personally am much more likely to do business with a company that is up front about every thing. |
#19 |
Liked 1,874 Times in 422 Posts
I only sell or use DLC when I'm also selling or using a steel cam. Most guys in Stock seem to still be using cast core camshafts, and that means no DLC.
I'm going to have to see some serious data from reliable known sources before using anything different. I don't even like DLC, any more than I like Shubeck style lifters. But DLC is "the devil I know".
Alan Roehrich 212A G/S |
#20 |
Apologies for the late response. I have been sick with COVID.
My goal here is merely to help shed some light on what we have all been discussing for some time now- the choices of lifters and steel cams and how it has affected the class and even the reliability of some vital engine components. First let me clarify my DLC Comments. I said “this may be better than DLC”. I am not arguing that DLC has been used or even may be useful in certain scenarios. Let me explain the difference in the two products and some of my background to help bring some clarity. I can tell you these facts: -is extremely slick-is slicker than moly and dlc -is itself a lubricant that bonds in a thin layer .5 to 1 micron with the surface by chemically interacting on a molecular level with the substrate. We use a proprietary technology called “Force Altered” under license from Force Altered Technologies, Inc. DLC is indeed very hard, but it is not extremely slick. The main drawback to DLC (aside from the ridiculous cost) is if you should experience the lifter bouncing off the cam (it can and does happen) the DLC will shatter and proliferate throughout your entire engine and cause a very expensive rebuild. The coating I am offering simply does not do this. We use a completely different process and the coating is not dipped, or uses a PDV process.. It actually bonds to the base material on a molecular level creating and new surface entirely. Is it proven? Yes. I have record holders using it and even the US Nationals winner. We haven’t even discussed piston rings yet. If you honestly want to know more I am happy to talk to anyone on the phone to discuss. This is just not the place to play 20 questions. I sincerely want to help and that was my reason for posting in the first place. Coated Lifters Pic.
Rocketmancoatings |
