Old 12-28-2022, 09:13 PM   #18
voltdr
Liked 100 Times in 51 Posts
Default Re: Head And Neck Restraints
[QUOTE=63corvette;672260]I have been using a Necksgen since 2013 when a friend died in a on track crash with a snapped neck.
All the head and neck restraints are much better than a neck collar which is really designed as a collar to protect from a fire.
My question is the head and neck restraint with a 5 year sfi tag required to be re-certified if the restraint is not required by the class rules you participate in?
I can not find a definite answer in the rule book.
I have been told anything with a sfi tag must be re-certified once the tag runs out by a tech person with NHRA.
I have also been told by a Division Tech Director if it is not required by the class it does not need re-certified.
Most of the racers I talk to goes with it does not like the Division Tech Director.
I just do not want be disqualified from a race due to a Head and Neck restraint sfi being expired which is not required for the class.
According to NHRA. Yes it must be kept current.
They won't disqualify you, you just have to go back to the neck collar until you get it current.
Dan Foley]
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
