#31 | |
Liked 7,783 Times in 1,743 Posts
#32 | |
Liked 1,851 Times in 418 Posts
Your combo cannot affect anything other than that same engine combo. If your combo has different heads, valve sizes, etc, then it doesn't affect combos that don't have the same specs. So, if your combo has 2.07"/1.725" valves and oval port heads, it will not affect a combo with 2.195" and 1.725" valves and rectangle ports.
Alan Roehrich 212A G/S |
#33 |
Liked 317 Times in 62 Posts
That's the way they say it works. For the 4.3 Chevy tbi engines they factor flat tappet cams, roller tappet cams, 108 wheelbase, 117 wheelbase, 430 lift cams, stock lift cams, cars or trucks together. All are considered the same engine family and body style.
Bob Shaw V/SA 515 |
#34 | |
Liked 271 Times in 107 Posts
Would sure save me a lot of money im fixin to spend. Probably have 200 stockers at divisionals. |
#35 |
Exactly!
#36 | |
Liked 692 Times in 200 Posts
Mike 7570 A/SA |
#37 |
Liked 231 Times in 107 Posts
They wouldn't do that. They paid a law firm to write the wording.
#38 |
The FE engine family is confusing enough with all the different variations. There are numerous combinations that could be in the same class. Now I see how this could help with the average for each because hardly any two 428 cars are running the EXACT same combinations.
Mike 7570 A/SA |
#39 |
What effect would bringing back the factory valve spring rule have?
Would this not simplify tech and negate some of the advantage found in cylinder head and intake advancement? |
