Old 11-03-2022, 03:07 PM   #1
Todd Hoven
Guest
Posts: n/a
Default Re: Billet cams and lifter supply
How much money will it cost when the 500.00 roller lifter explodes and it destroys the short block? Then we will need the parts to complement the lifters. Maybe titanium retainers, valves, etc. how much are Jesel lifters? 4K and up? Then we need keyed slot bushings for the good lifters. But this will fix everything, right. If I had to wait 14 months for tool steel lifters, I’d be trying to make a standard solid lifter work. Cam profile, spring combo, break in procedure and so on. Maybe you have to run softer profile cams so they last? Work with what you have? I’d take this route if I wanted to race and not sit out.
Remember when people on the board said if we just all had solid lifters it would be so much cheaper and easier to find and police? I guess all those people retried or quit racing? The same bullchit was said about roller rockers. Look where we are now?
Keep making these cars resemble SS rules cars and the NHRA can just cancel out the stock class and save a bunch of money and effort. They basically don’t want us there anyway. Your helping their cause by coming on here and asking for SS rules for our engines.
Forget about pure stock rules and enforcement. That ship sailed in the 80’s.
People here suggest a valve spring rule. That will even the playing field.
What happens when someone with a unlimited budget tells their engine builder to make that work no matter what the cost. Then you have put the cost even higher for racers to keep up.
If you want roller lifters in stock, run a car that came with them
Old 11-03-2022, 04:02 PM   #2
littlemanjoe
Liked 75 Times in 28 Posts
To me the madness needs to stop.
Repeat after me......Stock Eliminator.
Honestly we should be held to the same materials and type of lifters the cars came with. That's what makes Stock Eliminator so much fun.
If you want Super Stock options run Super Stock.
littlemanjoe is offline   Reply With Quote
Old 11-03-2022, 04:41 PM   #3
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
I knew it would only be a matter of time before you once again came up with your one sided reasons as you have in the past , you may not look the fool if you did not make up your one sided scenarios ,and look at today's facts ! When you use (someone) as you do that is a assumption of which you seem to have many , and not all are facts , I and others agree with you are cars are closer to super stock than ever , with that said
they are what they are today ,and today going forward is all that matters .
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 11-03-2022, 05:17 PM   #4
Todd Hoven
Guest
Posts: n/a
Look the fool? What did I say that’s one sided? What facts did I make up that’s not true? Roller lifters don’t break? People didn’t push for solid lifter years ago and now they are not good enough we need rollers? Sorry this displeases you. I thought this is an open forum with a free exchange of ideas. Just one opinion ( my own ) I’m not for the roller lifters in non roller combos. That’s all. Have a nice day
Some peoples moving forward may not be others ideas of moving forward.
Old 11-03-2022, 06:08 PM   #5
bubski
Liked 165 Times in 60 Posts
Bubski is like WTF !! At no time did Bubski say going back to the old rules would level the field !! Bubski is well aware of those that have the resources will always come out on top !! Money , contacts , and determination, etc !! Will always prevail !! What Bubski is saying !! " Lets bring back the STOCK to STOCK ELIMINATOR " NHRA has in the past reeled in the Pros to limit their performance !! And now its time to reel in the sportsmen !! 180-200 on the seat is laughable !! Most of the older engines were under a 100 to a little over a 100 on the seat !! How about a 10% increase from the old tech sheets across the board on seat and open pressures ?? Everyone now gets the same thing !! Remember !! Besides from bringing Stock into Stock !! Its not any good to race in Stock if you can't get the parts to show up and race !! Going back to what always worked before must be better than starting from scratch with a bunch of Hi Dollar parts that are not in the Spirit of Stock !! More like SS
bubski is offline   Reply With Quote
Old 11-03-2022, 06:29 PM   #6
Mark Lewis
Liked 209 Times in 46 Posts
Machine at PPPC is not fixed. I was there this morning. Have plenty of raw material to work with but no machine to operate. Also the operator didn't know when it would be fixed
Mark Lewis is offline   Reply With Quote
Old 11-03-2022, 06:40 PM   #7
john ancona
Two simple questions 1. This has been said for months now ,I was told it was the computer that needs repair
2. How many back orders are there
If I/we can get the answers it may indicate the likelihood if I/we ever see our lifter orders filled , case in point if it is 1 or 2 orders pending then the chances are slim to none
Old 11-03-2022, 07:20 PM   #8
SSDiv6
One of the many issues is the quality of the lifter, especially, materials and sizing. The sizing problem creates issues with lifter bore clearance and also when the lifter does not have a crown and the lobe does not have a taper.
It does not matter if the valve spring pressures are restored to the old rules. Too may engine builders are seeing camshaft and lifter failures even on mild street builds.
There is only one lifter manufacturer for solid and hydraulic lifters left in the USA.
Old 11-03-2022, 06:38 PM   #9
Billy Nees
Ya know, just when I was starting to kind of like you! There's no way that we are going to go back to OEM valve springs. It would be too much for too many combos to absorb and NHRA has proven time-and-time again that it's not going to allow combos to be turned into trash overnight (lawsuits?).
Knowing what some smallblock Stockers are running for spring pressures now, I thought that 180-200 would be an acceptable (and easy to police) compromise.
Billy Nees 1188 STK, SS
Old 11-05-2022, 10:10 PM   #10
4284spd
4284spd's Avatar
In this whole thread, maybe 10 actually race Stock. Nobody currently racing is going to want to go slower so that's a huge fail for all the valve spring pressure guy's.
2nd It's 2022 not 1967! Get over it!
3rd Rollers don't effect the looks or purpose of the class. It adds reliability. Again it's 2022!
No parts = no racers!!! JMO
BTW This bubski talking in the 3rd person is just a pathetic Look at me ploy! Grow The F up!
Bob Smith
