Old 11-04-2022, 12:21 PM   #1
Nmbr1GMfan
Default Re: Billet cams and lifter supply
I have a cast cam, removed the billet core so we could try a different grind, everything looks good but I'm sure it's all on borrowed time. I would like to get a billet copy of our current can but that is obviously an issue. Here was my fix...I ordered a roller cam, aluminum heads and manifold, plus a 4150 carb and a nitrous kit. I'll mothball the stocker stuff and maybe someday when lifters aren't $2k we'll return...maybe not.
Todd Greene
Old 11-03-2022, 07:05 PM   #2
john ancona
john ancona's Avatar
Liked 187 Times in 58 Posts
Originally Posted by SDT1DYI View Post
John, I thought you were going with to race SS GT class with a 350 2 barrel?
How about a 5 HP penalty for Roller cam in stock?
If a change to Roller Cams is made then change the piston rings to what ever rings you want. Spacers are get expensive as well. Oh and then for low compression motors how about making pump gas legal in stock as well. Could save some money there as well. .
Steve Teeter Stk/SS 620
Yep still going with the 350 2 barrel that is if there's still a track left in town LoL
John Ancona 717 STK / SS
john ancona is offline   Reply With Quote
Old 11-03-2022, 07:15 PM   #3
Liked 10,941 Times in 2,259 Posts
Y’all get the rules fix and we will try to live by them.
Old 11-05-2022, 05:55 PM   #4
Terry Cain
Terry Cain's Avatar
Liked 231 Times in 107 Posts
I like the pump gas idea.
Terry Cain ???? STK
tcain19689585@gmail.com
Terry Cain is offline   Reply With Quote
Old 11-05-2022, 06:43 PM   #5
1347
1347's Avatar
Liked 1,032 Times in 283 Posts
I think the biggest problem would be fuel check.
Duane Hoven
1342 SS/GT
1347 is offline   Reply With Quote
Old 11-05-2022, 07:21 PM   #6
Casey Miles
Liked 508 Times in 92 Posts
I still remember the spring numbers, 98 lbs seat and 202 lbs open. I was tossed once for being 2 lbs over. I'd be fine going back but that's just me being a purists for Stock. True hydraulics and only oem solid lifter cars. That would make nobody going 1 second under.
I not saying that it should go to the old way, just an opinion.
Casey Miles
248H Stock
Old 11-05-2022, 07:41 PM   #7
Rich Biebel
Rich Biebel's Avatar
Liked 557 Times in 217 Posts
Hydraulic Chevy cams were allowed the stock spring at about 84-86lbs on the seat. Single spring with a flat damper.
6000 rpm give or take a few hundred was all you were good for...1970 Stocker....
Rich Biebel
S/C 1479
Stock 147R
Old 11-05-2022, 08:15 PM   #8
Rory McNeil
No idea is they still make them, or they would be applicable for use in a Stocker engine, but I have an old Iskenderian Cams catalog, and they had a line of "Hardface Overlay" cam lobes, to be used with their "Chilled Iron" lifters. Anybody familiar with those items?
NHRA 6390 STK
M/S 85 Mustang
