Old 10-18-2022, 05:31 PM   #1
dab1550
Default 12V or 16V
I'm currently building a dragster to run S/C, Bracket race & the occassional foray into T/D. Would I be better off with a 12V AGM battery or a 16V Lithium? What are the pros & cons of each?
dab1550 is offline   Reply With Quote
Old 10-18-2022, 10:41 PM   #2
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: 12V or 16V
I have a couple of my Stock Eliminator customers running 16V Lithium batteries from AntiGravity Batteries with good success. one has been using them for almost five years , his first ones lasted almost 4 years . I should mention he runs 2 batteries.
Charging recovery time is a concern although he has not had problems when hot lapping.
That said , I still prefer 12V AGM batteries . The Lithium batteries are great for Class cars where every pound counts to get to minimum weight .
In classes where hitting minimum weight is not a concern I like the 12V batteries because they are far less expensive ,you can charge them at a much faster rate ,and the big one , if you have one fail its far easier to find a replacement at the track or the nearest Walmart .
Tom Goldman is online now   Reply With Quote
Old 10-19-2022, 06:02 AM   #3
Keith 944
Keith 944's Avatar
I’m with Tom on this, I like my 12v agm I get the biggest, heaviest one I can find. I need to add weight anyhow. The one in car now was new in 2018, I will replace now and use that one in my ramptruck for another 4-6 years lol. I have also heard that a 16 v gives no warning when it goes, but they say it spins motor over nicely. Although I had people say I was using 16v when they here my meizere starter. And I believe cost is another factor. You have to buy a charger to go with the 16v. It’s all whatever you want to do. I’m sure you will be fine either way.
KEITH MAYERS
2-1/2 X somebody
Still many X nobody
Old 10-19-2022, 09:10 AM   #4
sst5167
sst5167's Avatar
Liked 17 Times in 9 Posts
Funny you should ask this now, as I literally just came back from my first race after switching from 12v to 16v. Since the first day I raced, I have run nothing but Optima Red Tops. I have always gotten long life out of them and they never let me down at the track, so I could never see any reason to change. My current engine however, has always fought me to fire up after the engine gets hot. After a run, it would crank very slow and hard. I did A LOT of research on 16v batteries and decided on the super light weight Go Lithium batteries. My biggest fear with a lithium battery was the obvious, FIRE! Go Lithium uses lithium iron phosphate which is incombustible. So that solved my first and biggest fear. Second, I've heard horror stories of 16v batteries failing without warning. Go Lithium claims 10 year battery life, so I spoke to several racers that run them. A couple of these guys have had them in there cars for 7 and 8 years without a problem, and they're still going strong.
Now for my own personal experience.....I know, it was just one weekend, but I now see what I've been missing out on! The hard starts completely went away, and I swear my cooling time between rounds got cut in half! The fan and water pump run much faster now. My car would go from 185* down to 120* in 15 minutes, and the temp outside was 92*. The batteries would be back to a full charge in 18-20 minutes.
I am definitely a believer. So much so, that I'm now going to start selling them. If you have any more questions, please feel free to hit me up.
sst5167 is offline   Reply With Quote
Old 10-19-2022, 04:51 PM   #5
dab1550
Thanks for all the reponses. I'm leaning towards the Lithium as weight is a concern.
Old 10-20-2022, 07:20 AM   #6
sst5167
sst5167's Avatar
If you decide to go with Go Lithium, send me a DM. I can send you promo code for a discount onthestopworkshop.com/shop
Old 10-20-2022, 12:42 PM   #7
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I've been a 12v guy forever in both of my cars. This season I ran a couple races in a car equipped with two Go Lithium 16v batteries.
I don't know if I'll make the change, but I'm at least doing some thinking about it.
S/ST 51
S/C 53
Old 10-23-2022, 12:43 AM   #8
voltdr
Liked 100 Times in 51 Posts
I’ve been running (2) GoLithium 16V batteries for a couple of years now and would never go back. I run SC and have zero issues with starting, oolong or hot lapping.
Dan Foley
SC 44
Dan Foley
SC 4698
voltdr is offline   Reply With Quote
Old 10-23-2022, 03:11 PM   #9
Chip THELEGEND Johnson
Liked 281 Times in 79 Posts
Been using Rock 16v for nearly 15 years. I use 2 with no alternator
Chip THELEGEND Johnson is offline   Reply With Quote
Old 10-23-2022, 06:54 PM   #10
Average Joe
Liked 18 Times in 8 Posts
I have 2 go lithium 16V and would never go back to 12V. I like the weight savings and how it spins the starter.
Average Joe is offline   Reply With Quote
