Old 10-04-2022, 12:39 AM   #1
Mike Gray
Mike Gray's Avatar
Liked 687 Times in 198 Posts
Default Re: MSD grid
Originally Posted by NHRA1926 View Post
Anyone using the MSD power grid to run Super Street? My Digital 6AL Plus has issues, so I ordered the MSD grid system and gonna try to use it to adjust timing to run 10.90. Any one out there got any experience or suggestions? I do not use a conventional throttle stop, just a manual limiter on the back of the carburetor. Trying to let the car launch hard, then pull timing out to hit the 10.90 mark.
It became much easier to run Super Street & Super Gas using a good throttle stop controller. I tried the manual limiter but if your trying to kill much et it creates a bunch of problems. I finally gave in a got a Dedenbear timer and air actuator on the linkage. Much more consistent and you can use it at either end.
Mike 7570 A/SA
Mike Gray is online now   Reply With Quote
Old 10-05-2022, 03:14 PM   #2
Maverick
Liked 36 Times in 26 Posts
Hey, Keith, I know you can change the start rpm, but I don't think you can change the timing, you can see what the timing is, but you can't change it
Old 10-06-2022, 10:05 PM   #3
DailyDriverSst
Liked 7 Times in 6 Posts
Very doable.
Tip: Leave your timing degrees the same, just move the curve in and out.
At 5 degrees, I've observed a 10:1 ratio
IE, putting timing in at 1.8 on one run and 2.5 on the other run, slowed the car 7 hunds. 7 tenths of timing was 7 hunds of ET. But that's in a very specific application. YMMV.
DailyDriverSst is offline   Reply With Quote
