Liked 345 Times in 149 Posts
This week the plumbing was completed. I used Brown & Miller PTFE lined, aramid fiber braid hose with their crimp on hose ends. Light weight, very flexible and should last for a very long time compared to rubber lined hose.
One other little fabrication project was to make a bracket to attach the 10 oz c02 bottle to the side of the fire bottle. Pro Werks billet clamps finished off the mount. Need to drop the bracket off for powder coating.
Liked 26 Times in 11 Posts
Hello Todd,
Please explain the shift linkage. I'm certain I'm missing something. Thanks. See you at the races, Wayne Kerr |
The travel sensor on the transmission linkage can be used for numerous things when tied into the Holley Dominator EFI.
Can be used for reverse lights, shift indicator, neutral safety switch, high gear timing retard, as well as idle circuit fuel/spark map adjustments to keep from dropping rpm when put in gear. I’m sure there is even more it could do. |
Thanks Todd, didn't know it was a linear potientiometer.
That splains it. See you at the races, Wayne Kerr |
Monday (yesterday) was another milestone in the build. Was able to fire up the engine and with some help get the efi adjusted some. Went well, so the next move is to drop the car back off at the body shop to install glass, trim and some other small things.
After that it’ll be time to put the car on a chassis dyno to work on refining the efi tuneup further. |
C02 air cylinder mount powder coated and installed.
