Old 07-24-2022, 09:59 PM   #11
Todd Geisler
Liked 345 Times in 149 Posts
Default Re: 8.50 index build
With the wiring pretty much done, it was time to install the transmission and converter. I had concerns over the converter pilot length given this car has an additional 1/8" block plate along with the 1/4" midplate. And sure enough, the pilot is too short as are the block bellhousing dowels. So while the trans was still in the car I wanted to weigh the car before removing it to resolve the two trans issues.
Weight as it sat on the scales, no driver.
I also weighed and accounted for all the parts not bolted to the car yet.
and a quick weigh with driver...
So in the end the car should be right at 2640 lbs with driver, race ready.
Todd Geisler is offline   Reply With Quote
