Liked 239 Times in 90 Posts
Talked with Dart today. The 305 little M block is no longer in existence. Discontinued. They are replacing it with a 305 SHP block but it will be at least 6 months before one is produced. Oh, and the part number changed and the new number is NOT on the approved list.
Little M 305 31151411 New SHP 305 31161411 |
Liked 348 Times in 152 Posts
And from what I've been told the SHP blocks are now being cast in China
Phil Molski PMR Performance S/C 1623 |
Liked 10,835 Times in 2,252 Posts
Would a sleeved 400 block work, it would have thick cylinder walls.
Liked 22 Times in 6 Posts
I purchased a 305 Little M block in early 2020 but it was stolen out of my engine builders shop, and then Dart discontinued them. Now it appears they are making a new 305 block with a different part number.
I'm kinda new to all this, what is the procedure to get the new P/N approved? Can I initiate it or does Dart have to? Thanks.
Tom Johnston 3177 84 Cutlass 305 L/SA M/SA |
#5 | |
The mains are a different size - I don't know if spacer bearings would be legal?
#7 | |
Liked 520 Times in 176 Posts
I haven't done this myself - yet, but wouldn't a good 4" 350 block be a reasonable choice? Main bores are right size and the cylinder walls (once sleeved ) would be pretty thick as well without the cooling problems like cracking from the steam holes between the cylinder bores. Just my 2 cents from my little corner of the world! Respectfully, Henry Kunz 1534 H/SA |
#8 | |
Liked 49 Times in 15 Posts
Sleeved blocks work very well if done properly. I have a 350 block that is sleeved and a 307 block that is sleeved. Personally, I think the 307 block is better as it was an early casting block and had very thick cylinder walls to start with. I know that people say it costs too much or it's too much work to sleeve a block. But when you factor the cost of an aftermarket block and all the required machine work to true up every surface of a new block, I don't think those claims are valid. But I'm old and my stuff is slow, what do I know
Dean Feiock -- Stock 5002 Last edited by Dean Feiock; 07-15-2022 at 05:51 PM. |
#10 | |
Liked 17 Times in 6 Posts
https://www.competitionproducts.com/.../#.Yt3EtXbMKM8 Last edited by tscheerer; 07-24-2022 at 06:23 PM. |
