Liked 150 Times in 41 Posts
Bubble flare is very common on todays automobiles, You mostly see it on 3/16 brake line
Liked 51 Times in 30 Posts
basically a double flare and not doing second step
Liked 263 Times in 68 Posts
Bubble flares are used on brake lines
John Dinkel 3295 STK |
Liked 72 Times in 36 Posts
Thanks to everyone who answered my question. I knew the Bubble Flare was different from the others because it required a different flaring cone all together and i had never seen one so that's the reason why I asked. Once again thanks for the response.
Kenney Kelley |
Liked 10,712 Times in 2,230 Posts
I’m never to old to learn. Thanks everyone
Liked 237 Times in 126 Posts
A bit late but a bubble flare is a European standard and not common on US cars. Not sure its road legal in this country. Inverted double flare is stronger. Always match flares and fittings. Here's a chart.
https://www.mpbrakes.com/images/MPB-F200-22.pdf
Liked 1,583 Times in 582 Posts
A word of caution.
If you are using a bubble flare, make sure the mating components are designed for a bubble flare. The flare has a different shape and will not fit into double flare connections. You cannot connect a bubble flare to a double flare seat. They have a built in crush surface which means that the flare can not be reused. You also can not connect a bubble flare to a double flare seat. |
#8 | |
Liked 133 Times in 76 Posts
