Old 05-25-2022, 08:57 AM   #11
tstickff
tstickff's Avatar
Liked 561 Times in 138 Posts
Default Re: Grade points
I’ve always found this to be bull ****, if you want a grade point you should have to be on the Q sheet and pass fuel check, if you choose to leave after that then so be it. Give another racer a comp single then you both have benefited. But just buying grade points is BS..
Tim
Tim Stickles
tstickff is offline   Reply With Quote
