Old 05-20-2022, 09:04 AM   #5
Eddies66
Eddies66's Avatar
Liked 881 Times in 452 Posts
Default Re: VA Loan First Time Home Buyer - VA Loan Explained
Originally Posted by FED 387 View Post
lot of good points here ---do your homework its fairly easy if you do it right-- I'm on my 3rd VA home loan ---just the usual piddly *** stuff no peeling paint etc. but it can be done you just have to be patient--also you may not have to pay the 2 1/2 % funding fee if you are a disabled vet also when you finally buy your home IF you have any VA disability you may be able to eliminate either a portion or your entire property taxes depending on the state you live in ---its worth it check it out---FED 38
Good advise, keep in mind each state has different rules. Just need to do your homework.
Eddies66 is offline   Reply With Quote
