#41 | |
Liked 273 Times in 109 Posts
Have you filled out an online tech card lately? There are questions and answer spaces there pertaining to everything from head casting numbers to neck collars, parachutes, window nets etc. And a disclaimer that says I know what my car/class requires. and I'm good. If a spot check determines otherwise...well then you got some splainen to do! |
#42 | |
And if y'all don't think they're on top of this... couple yrs ago I filled out my online tech card... trans blanket...yes...I did not list the mfr. Q1 at fuel check tech man said.."what trans blanket is that?" I said I don't know,it was on the car when I bought it. He did not toss me,he did not DQ the run. He said " it's your responsibility to know! When I ask you this question after Q2 you better have an answer!" |
#43 |
Liked 1,361 Times in 416 Posts
Window nets are a two year cost like seatbelts too. Certified rollcage is a two year cost as well required to go 9.99/135.
#44 |
Liked 1,986 Times in 599 Posts
Someone would have had to bring this up to a tech official for anything to be done after the run. Lots of drivers stop at the top end on the return road and take all of their safety gear off before going to the scale. No way the scale guy would know how fast the car just went on the run or what gear the other driver was wearing. The staring line crew might have a chance at seeing what safety gear each driver had on and the time but they also have many other responsibilities at the starting line. If you see a competitor you are running and he has something that is not right and you feel someone needs to know about it then it is up to you to alert the tech dept. and make a complaint. Then they can decide what action to take if any.
Mike Pearson 2485 SS |
#45 |
Liked 360 Times in 121 Posts
#46 | |
Liked 431 Times in 224 Posts
As far as safety equipment goes, I think the current method is more safe than it used to be. No longer can you bring your legal stuff to tech and then switch to your favorite expired stuff for the race. This past weekend in Great Bend, they even made us all pull over on the way to the lanes to test the neutral safety switch.
S/ST 51 S/C 53 |
#47 | |
Liked 83 Times in 32 Posts
#48 |
The insurance carrier for the N.H.R.A. wouldn't be happy about that.
#49 | |
Exactly as a former track operator I see peoples comments about well let him go, well if something happens insurance will not be responsible, and trust me more times than not when someone is hurt there is a lawsuit. Some of the most cut and dry cases of racer stupidity ended up with a lawsuit against the track and sanctioning body. |
#50 |
Liked 472 Times in 72 Posts
Moving to one second slower,, Any car in competition,with an automatic transmission, capable of running 10.99 or quicker must have a transmission shield or blanket,,period. Since we have been running a few 10.99 or better it was very politely pointed out by a Division 1 Tech Official that we need a blanket or shield for our Camaro transmission. It's on and now we are in full compliance with safety rules. It was clearly visible in our picture in National Dragster that our transmission pan was very easy to see and blanket was missing. I thought it was going to be an all day project to install this blanket but it was actually pretty easy.
