Liked 544 Times in 213 Posts
No there is no adjustments on the battery charging output
Not even sure you have that as on those machines I believe it was optional Most MH's have battery charging converters/chargers so a battery charging output is not needed Anytime I have someone with this issue I advise them to hook up an external charger. Far easier and cheaper Access to any machine for repairs is often a big problem and I always evaluate the job before doing the job. Removal is sometimes the only way to do a repair. Some installs were done as if there would never be any need to work on the machine.....a big mistake...... I change those temp sensors anytime I'm inside a 7.5 Onan. I've seen them with a lot of deposits in the pocket below the sensor. I think it was from Dex-Cool type antifreeze.....Don't use it ! I use green A/F......
Liked 10,721 Times in 2,232 Posts
Thanks Rich. You hit the nail on the head, lots of deposits around the sensor. A battery charger it will be with green antifreeze.
