Old 03-29-2022, 04:19 PM   #1
jamie2370
Liked 239 Times in 90 Posts
Default Re: 79 Malibu- Stocker-Stick Shift
Studs have a different clamping force than bolts. That is why they are used under higher cylinder pressures. Also they will cause cylinder roundness issues if they weren't used to hone it. A bracket motor you may never see the difference, a stocker motor on the other hand you.....
jamie2370 is offline   Reply With Quote
