#21 |
Liked 2,361 Times in 558 Posts
The 6.2 (376) in the 2010-2015 Camaro is the production LS3 combination.
The COPO 6.2 is LT based (2016+). It uses the production block, crank, and heads. It has a bigger cam, more compression, ported heads, and a Holley Hi Ram intake. The 2016-2020 is direct injected. The 2022 is port injected.
Daren Poole-Adams NHRA Stock/SS 2007 |
#22 | |
Liked 101 Times in 52 Posts
#23 |
The LS3 is about 65 PSI at the injector.
The DI is 100 PSI to the mechanical pump and around 3,000 PSI at the injector.
#25 |
#27 |
#28 |
We run the LT4 fuel pump.
#29 | |
Liked 904 Times in 237 Posts
Barry sell the 69 for $60,000 and then buy the new car for over $100,000 is the way it works out lol
Don Kennedy 7701 SS |
#30 | |
Guest
Posts: n/a
I have a couple of guys probing me to buy it. If I could pull it off I probably would. Except for being in C a l i f o r n I a and trying to race here - all is good. Miss you guys! |
