#11 |
Liked 18 Times in 9 Posts
I have run my Super Stock 69 Camaro with cowl scoop open and closed.
No difference! |
#13 |
Liked 1,144 Times in 354 Posts
I found one pretty cheap, I will restore it and try it, if it doesn't work I will sell it, they are hard to find.
Randy Wells I/S 5628 |
#14 |
Liked 24 Times in 8 Posts
NOT a hood scoop, but cold air cleaner housing to fender tubes to the front on a Fox Body car. Fresh air instead of hot air under the hood. It was worthy in this part of the country in August.
#15 |
Don, my 85 5.0 carbed Mustang also had the ducting from behind the bumper to the inner fenders, but I tried back to back testing with the factory dual snorkle air cleaner with the plastic flex tubes connecting the fender ducts to the air cleaner snorkles, with and without a K&N filter inside, and basically it ran the same with or without the air cleaner housing on, or just letting the ducts blow the air all around the engine compartment. Maybe that huge aluminum air cleaner assembly trapped enough engine heat between the intake manifold and carb, to offset any benefit of potentially cooler air going into that "oven".
#16 | |
Liked 163 Times in 53 Posts
Stephen Johnson #2162 Horace Johnson #2167 SS/D 427 Ford Fairlane NHRA-IHRA |
#17 | |
#18 |
Its ugly but if it works for a couple hun I can live with it. I did remove the snorkel.
#19 |
I did some testing today at Heartland Park Topeka, not a good day to test but did get my clutch dialed in. A steady head wind 19MPH gusting to 26. fastest run 11.746 @ 112.54 made 6 runs, slowest 11.82 @110.85, last run of the day with the air induction air cleaner 11.772 @ 111.98 with 22 MPH head wind, and there was no starting line prep, bunch of street cars tracking water to the line all day. May have to try the cowl induction again Thursday in Noble Ok.
