327 275 hp .060 bore Total Seal Rings with gas port spacers
CP pistons Crower Billet rods steel Billet cam shaft and tool steel lifters coated Heads Up cylinder heads Comp Roller Rock Arms Comp Push Rods ATI Lightweight Balancer Dart SHP Block $10,000.00 Intake to pan FRESH 2.08 gear set with aluminum reverse ring gear--NEW $1,000.00 Small journal 327 crank shaft, standard rod and main $200.00 Rodchester 207 race carb $800.00 Pair of 462 heads by Heads Up FRESH $2000.00 Set of CP 327 pistons with spacers NEW $1600.00 Gale Pinkston 931-684-4463 Send your cell number to 931-639-7065 and I will send you pictures Last edited by Gale Pinkston; 03-01-2022 at 11:21 AM. |
Liked 56 Times in 31 Posts
You have a PM
Thomas NHRA 1959 D/SA |
